How to fix cracked balcony edge?
kyap
The edge of our balcony is cracking and lets water in (although so far have not noticed any leaks into the house; balcony overhangs the front patio). This was noted in the inspection report before we moved into the house. I've had trouble finding someone to fix this as it's such a small job so will likely need to fix it myself. One of the trades who came to look at it suggested duct tape over the top to stop the majority of the water seeping in, that was almost 2 years ago now and the duct tape is still there - figure it might be time to do something more permanent.
I was thinking I either try to regrout the edge but that could be quite messy.
Alternatively most of the trades suggestions have been to get a 1mm sheet of aluminium cut to size and affix that to cover the edge. This might be beyond my capabilities (don't want to drill and crack the existing balcony even more) and I've no idea where to order something like that from.
Any other suggestions?
Re: Cracked balcony edge
Hi @kyap,
It sounds like a good time to tackle a more permanent fix. Before anything else, you’ll want to remove any deteriorated silicone (the grey substance previously used to fill the gap). Once that’s done, sand down the metal to remove any rust and then paint it to prevent further corrosion.
After painting, you can apply a flexible polyurethane sealant such as Sikaflex 11FC to the area to ensure a proper seal. If you’d like to improve the look of the balcony edge, adding an aluminium trim over the top is a good option. You don’t need to drill into the existing structure—simply pressing the trim onto the Sikaflex directly after it has been applied should hold it in place securely.
