Can I get HardiPlank boards cut to length?
stan0811
Can I get HardiePlank weather board cut to length?
Re: HardiPlank
Hello @stan0811
Welcome to the Bunnings Workshop community. It's a pleasure to have you join us, and thank you for sharing your question about cutting Hardie Plank.
Unfortunately, this service is currently not offered at the store. If you're planning on cutting more than one hundred panels, I suggest investing in a Circular Saw in conjunction with a circular blade that's rated for cutting Hardie Planks. Please make sure to ask for assistance from the senior tool specialist in the store to make sure that you get the correct products.
Hardie Planks can also be cut with Angle Grinders and with a traditional Kincrome 150mm Folding Lock Back Utility Knife. Please note that snapping the Hardie Planks by hand will require you to sand the ends for a smooth straight finish.
