Best filler for gaps in blueboard joins?
ac1977
What is the best gap filler to use on blue board
Re: filler for gaps in blueboard joins
Welcome to the Bunnings Workshop community @ac1977. It's fantastic to have you join us, and many thanks for your question about filling the gaps between blueboard sheets.
Are these large gaps or very fine gaps? Perhaps you might like to show us some images of what you would like to fill.
The gap between sheeting is normally set with Dunlop 3kg Fibre Cement Jointing Compound and Builders Edge 50mm x 90m Alkali Resistant Render Fibre Cement Tape in much the same way Gyprock plasterboard sheets would be. The tape is used to prevent the jointing compound from cracking. I'll include a video below which shows the process on interior Villaboard sheets as it's a similar method.
Hi Mitchell,
The boards were originally painted over but I want to fill the gaps before painting a different color.  Attached is a image showing the small gap
@ac1977,
That's a gap that should probably have been set originally with the above-mentioned products. Now, your best option might be to use a flexible and paintable polyurethane sealant like Sika 300ml White Sikaflex 11FC Plus Polyurethane Adhesive Sealant. It's a great product for joints that might expand and contract.
Can you tape the blueboard joint then patch of compound?
Hi @ac1977 if your looking for a basic cosmetic fill, James hardy make a product called a "Horizontal Trimline Joint Flashing" which come in various widths and 3m lengths and can be ordered via the special orders desk at your local Bunnings. It's pressed into position and fixed with silicone sealant.
Regards, Nailbag
Hello @bob1234
If you are using the Builders Edge 50mm x 90m Alkali Resistant Render Fibre Cement Tape, you can place the tape over the blueboard before using the patch compound.
bob1234
Eric,
thank you for your help. I am using the tape you mentioned and Dunlop joint and patch on Blueboard with the aim of applying a Dulux texture paint. Is the joint patching product the most suited and will the jointing show with the texture paint? Also is the Dulux fine texture paint the most suited.
thank you in advance
Hi @bob1234,
The Dunlop 3kg Fibre Cement Jointing Compound is suitable for setting your Hardietex; Hardie's does not supply a specific product for this.
Provided you set the joint so it is flush with the elevated portion of the board and sand the finish smooth, the joints should be virtually invisible once you apply textured paint. The Dulux fine texture is certainly suitable, but it's more about what you'd like the finish to look like. The fine texture will give a small amount of texture, mimicking a fine render. If you wanted more of a rough-looking render finish, you'd need to go for the medium or full-cover texture.
