Backyard Discovery 3.7 x 3.1 x 3.1m Brindlewood Gazebo I/N: 0295663
Dan1966
https://www.bunnings.com.au/backyard-discovery-3-7-x-3-1-x-3-1m-brindlewood-gazebo_p0295663
We're considering this Gazebo for our outdoor area to use for what will eventually be over a spa.
It ticks the boxes for looks and strength quoting a 160km/h wind rating but has anyone built one of these and what documentation is available from the manufacturer for council approval as I believe council would require engineering drawings for approval?
Re: Backyard Discovery 3.7 x 3.1 x 3.1m Brindlewood Gazebo I/N: 0295663
Hi @Dan1966
I had a look at the gazebos that were on offer and could only find the Mullaloo, Lava Brighton and the Softwoods Gazebo kit that have drawings attached to them.  The drawings for the other gazebos will probably need to be requested. In regards to the fire rating of the Mullaloo, I believe it falls under the AS/NZS 1530.3 being a metal structure. However, I'll get you more details regarding this.
Thank you for your patience.
Dan1966
Hi @EricL
Just wondering how you are going with the request for Engineering Drawings and Fire Rating Information for the https://www.bunnings.com.au/mimosa-3-62-x-3-3m-mullaloo-timber-look-gazebo_p0262348 - Is the supplier able to provide a Form 15 QLD Compliance Certificate for this Gazebo or how would this be obtained? These are both required by the certifier in order to approve the council request.
Hello @Dan1966
I'm sending the engineering plans to your email, I'm sorry but I've yet to receive an update about the fire rating for the Mullaloo gazebo. I'll ask them about the form 15 compliance certificate as well. I'll make further inquiries and get back to you.
Dan1966
Good Evening Eric,
Just touching base again regarding the fire rating and Form 15 request for the Mullaloo ?
Dan
Hi @Dan1966
My apologies for the delay, I've sent you a message in your PM box.
Dan1966
Hi Eric
Just reaching out again as all three QLD certifiers I have now spoken to are saying: "In accordance to Qld building regulations we will require a form 15.  The manufactures should be able to supply this. One of our builders mentioned the other day that you can apparently log on to bunnings and get the form 15."
Hoping you can assist or can you provide a contact at the manufacturer that I can speak to to have this supplied.
Dan.
Hi @Dan1966
My apologies for the delay, I've been searching for form 15 on the site but can't locate it. However, a blank form 15 is available at the Department of Communities, Housing and Digital Economy - Form 15 Compliance certificate for building design or specification. But I believe that another iteration of this form might be available at your local council's office.
Dan1966
Thanks Eric - I'm not looking for a blank one - they need to be filled out by an engineer hence why they are supplied by manufacturers.
Could I please have a contact name for the manufacturer of the Mullaloo Timber Look Gazebo so that I can get this build underway?
Dan
