Are there any foam cannon adapters for Ryobi pressure washer?
Trever
Growing in Experience
Are there any adapters or methods for my (1/4” Standard Quick Connector) foam cannon to fit the (18V ONE+ 320PSI EzClean Power Washer) or (Ryobi 2000PSI pressure washer RPW140-G).
I also saw a product for the 18V ONE+ 320PSI EzClean Power Washer that is what I need on the Ryobi Website but it is coming soon.
Re: Are there any foam cannon adapters for Ryobi pressure washer?
Hello @Trever
Thanks for sharing your question about Ryobi adapters. Is the connector you are referring to a sliding brass coupler? Would it be possible for you to post a photo of the connector of your foam cannon? I could only find the Ryobi Backwards Compatible Adapter and I'm not sure if this will fit your foam cannon.
However, Ryobi does have a Ryobi 600ml Pressure Washer Detergent Bottle. It is compatible with the pressure washer units RACPWS1, RACPW140, RACPWS2, RACPWS3. Any extra information or photo of your preferred adapter would be very much appreciated. This will also help us to try and track it down and see if it is available.
If you need a hand posting the photos, please let me know.
Trever
Thanks for your reply, the image above is my foam cannon 1/4” Standard Quick Connector.
The EZ CLEAN POWER CLEANER 1/4" QC WAND ATTACHMENT was the attachment that I mentioned before that was coming soon.
Here is the photo:
Thank you
Hi @Trever
Thank you for posting those photos of your foam cannon. Yes, I saw that adapter on the Ryobi website and there is still no word when it will arrive. I'm sorry, but I've not seen any other adapter that will work. Hopefully, Ryobi will make this product available at the store soon.
In the meantime, I can only suggest using the Ryobi 600ml Pressure Washer Detergent Bottle until the adapter becomes available.
