Anchoring Deck Joists to Concrete
JesseS6
Growing in Experience
Hi All,
Looking for advice on achnoring decking joists to concrete for a low level deck. My joists will be 140mm x 45mm with 140 x 19mm Merbau decking. Overall clearance from conreate to top of deck is 180mm.
Current plan is to use-
Carinya Heavy Duty 75 x 75 x 40 x 3.5mm Zinc Plated Reinforcing Angle Bracket
Dynabolt these to the concrete with - one - Ramset 10 x 75mm DynaBolt Plus Hex Nut Bolt (do i need to use something different on the perimieter of the concrete?)
Question 1 - what should I use to fix the Joist to the Angle bracket?
Question 2 - Is flashing or Protectadeck joist protection required/overkill?
Question 3 - This will be a picture frame deck, for the two ends that require a second joist with the offcuts, what screws should be used to fix these together, or do I need to run a bolt through?
Question 4 - where are washers required?
Question 5 - Is an SDS Hammer drill best for getting through conrete, and is a impact wrench best for tightning dynabolts?
Question 6 - If I'm using angle brackets to fix the joists to the conrete, are noggins required?
Thanks in advance
Jesses6
Re: Anchoring Deck Joists to Concrete
Hi @JesseS6,
If your fixings are less than 100mm from the edge of the concrete, consider switching to Ankascrews instead of Dynabolts, as they’re less likely to crack the concrete edge.
Adding protection like Protectadeck to your joists isn’t overkill—it helps prevent water from sitting on top of them and is a great way to extend the life of your structure.
For the picture frame ends, you can use landscape screws or large bugle screws to join the timbers. You’ll likely need spacers between the two lengths to increase the width and provide a better fixing area for the picture frame and board ends.
Washers aren’t typically used in deck construction unless you’re using bolts.
A SDS hammer drill is the best option for drilling into concrete, as it’s much faster and more effective than a standard drill with a hammer function.
For tightening Dynabolts, an impact wrench would work well, but a manual socket set can also do the job.
Lastly, noggins should be used to improve lateral support and prevent joists from twisting.
JesseS6
Thanks @MitchellMc ,
Where there is bearers under the joists, (for example when a deck is over concrete and soil) how should the joists be fixed to the bearers? is a Framing gun with a nail angled in on either side of the joist? (into the bearer)
Joist straps would typically be used @JesseS6. Skew nailing could be used, but with both fixing methods, noggins should be installed.
JesseS6
Thanks @MitchellMc , sorry for all the questions.
For the angle brackets, when fixing it to a joist, what should be used? a bolt through the joist or is a some sort of timber screw/coach screw?
Pryda Timber Connector Nails 35 x 3.15mm and used for those brackets @JesseS6.
JesseS6
@MitchellMc nails for the angle bracket that connects the joist to concrete?
I would of thought screws would be needed.
Hi @JesseS6,
I think @MitchellMc thought you were still referring to the joist straps which would use connector nails.
To connect the angle brackets to your joists, you should use bolts rather than screws. You should use the thickest galvanised bolt that will fit through the predrilled holes in the bracket. These Zenith M8 x 70mm Hot Dipped Galvanised Cup Head Bolt And Nuts should work, but you'll have to double-check in person to confirm.
Let me know if you have any further questions, I'm happy to help.
