I'm planning to build an outdoor pull up bar made entirely of metal, similar to the attached image.
Please help with any tips or suggestions on where to source the materials.
I was thinking:
2 - 3m x 80mm x 80mm hollow galvanised steel beams
1 - maybe a vulcan rig pull up bar
Concrete mix
Welcome to the Bunnings Workshop community @luv2diy. It's terrific to have you join us, and many thanks for your question about building a pull-up bar.
The closest post we are likely to have would be the Australian Handyman Supplies 89 x 89mm x 3.0m Galvanised Steel Fence Post - galvanised 3.0m. We've also got plenty of concrete mix for your project.
Most of our pull-up bars are not suitable for exterior use.
Hey Mitchell,
Thank you for your welcome and the advice!
Upon further research, I need two 89mm x 89mm x 5mm 4m galvanised steel square tubes (the key being it's at least 5mm thick).
I found such a product over East: https://www.themetalwarehouse.com.au/shop-online/steel/square-tube/89-x-89-x-5-0-square-tube.html
And suggestions on the best metal supply shops or fabricators in Perth to obtain this from?
Many thanks.
