Hi folks. I’m not sure if I loaded this “virgin” post properly yesterday, I can’t see any evidence of it here!!!
So let’s start again.
I have an ageing sliding aluminium framed glass door that is falling apart. The leading edge is pulling away, and I’m able to pull it completely off without much effort.
I have no idea how it was built, possibly recycled from Noah’s ark (at least 30y old) and I fear that if I dismantle it I won’t have the know-how to restore it!!!
$$$ are restricted🥴…
restore or replace…
Thanks Gurus, your advice is pre-appreciated.
Dave.
(note emergency repair at top)!!!
Hello @DaveScott
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your aluminium sliding door.
Sliding aluminium doors often have their fixings very well hidden or are placed in an area where access is not easily seen. Should you get lucky and find the fixing points, getting the right screws and making sure that they fit now becomes the main issue.
There is also the matter of the rubber seals surrounding the glass of your door. It appears that parts of it have deteriorated and must be replaced. Which then involves disassembly of the entire door, I don't recommend attempting this, especially if you've not done it before. Handling large pieces of glass is dangerous and any mistake can result in the glass shattering and causing injury.
I propose getting a repair quote from an aluminium/glazing shop that does windows and doors in your area. You can ask them how much it will cost for a home repair for just the door and the replacement of the doors rubber seal. Aluminium is a sturdy material and although it may look tarnished on the outside it is still structurally sound inside. I therefore suggest keeping the door and repairing it rather than replacing it.
