I was given this little bedside table as a part payment for another furniture makeover I had completed but after I had taken it I had second thoughts. Most pine bedsides are pretty much solid wood but this was largely all veneer, and damaged veneer at that. I knew if I were to make this over it would take more than cleaning and painting, it would require a whole new top and a whole lot of elbow grease as well๐๐
Maxi Nails: https://www.bunnings.com.au/parfix-300g-maxi-nails-construction-adhesive_p0443732
Round Wooden Board: https://www.bunnings.com.au/specrite-600-x-18mm-round-timber-multi-use-pine-panel_p0419618
Fine Sanding Block: https://www.bunnings.com.au/rocket-fine-sanding-sponge-fine_p1661077
Glitz Beeswax: https://www.bunnings.com.au/glitz-200g-beeswax-polish_p4460472
Floor Protectors: https://www.bunnings.com.au/surface-gard-assorted-eva-pads-56-pieces_p3970373
Calcium Carbonate: https://www.vetshopaustralia.com.au/cat-supplies/dietary-supplements/vitamins/vetsense-calcium-carbo...
Sanding Pads: https://www.bunnings.com.au/ryobi-125mm-orbital-sanding-discs_p0255337
Mistint paint pot
Drawer Knobs from Kmart
Ozito Orbital Sander: https://www.bunnings.com.au/ozito-230w-random-orbital-sander_p6290233
Clamps: https://www.bunnings.com.au/craftright-450mm-2-piece-quick-action-clamp_p5860151
Drill
Screwdriver
Circular saw (100 years old๐๐)
Hammer
I assessed the damage to the top and attempted to remove it. I knew it wasn't good and I was right!
There was also much damage to the sides but I decided to go ahead and use an old pine top I had bought for a previous project.
I sanded the top to remove the previous wash and glue marks and I also smoothed out the edges. There seemed to be a bit of tanin bleed where I had white washed previously but I wasn't too worried.
At this stage I was thinking twice about proceeding but thought what the heck I've come this far. I sanded back the wood filler and scuff sanded the body and drawers.
It was time to attach the top. I had intended to screw it on but it was a bit awkward, so I glued it and hammered nails in the back to secure it.
Next was cleaning, priming and painting. I have a collection of mistint paint pots, quite a collection๐, so I chose a color and then made some chalk paint by adding a tablespoon of calcium carbonate to about 250ml or one cup of paint.
Next was my favorite bit, applying the stencils to the draws. I made this silk screen stencil on the cricut machine previously and the stencils come out beautifully. It's so fun to do and I will be making more that's for sure!
I attach porcelain drawer knobs I bought from Kmart. I always try to buy them when they have reduced them to $2 a packet so they're ultra good value. Even though the holes were already there I did have to drill again to make them a bit bigger.
I now finish off the top I have replaced with a touch up sand and paint wash. I use the same color I painted the body and add a dash of water, just depending on how transparent you want the finish.
I always use Glitz Beeswax to finish. This protects and gives a finished look. I'm so happy with the final result, the top looks beautiful and I didn't have to buy anything to complete this, I just used what I had which makes it ultra good value for money!
What a lovely transformation @daniknight4. You must be so pleased with those results. I love your chosen colours, and that stencil work is wonderful.
Many thanks for sharing, and well done.
@MitchellMc @Thank you it was rewarding to do๐
