Remove built in wardrobe or makeover?
EllieBee
I have some built in wardrobes that I’m wanting to overhaul. I’m not sure whether I should gut them entirely or just add flatpack inserts?
It giving a makeover, what hinges would be recommended to use?
Re: Remove built in wardrobe vs makeover
Hi @EllieBee,
Deciding whether to remove a built-in wardrobe or give it a makeover depends on your goals, budget, and the wardrobe's condition. Removing the wardrobe entirely is a good option if the structure is damaged, outdated, or limits the room's functionality. It allows you to start fresh and design the space to fit your needs, but it can be more costly and involve additional work, such as repairing the internal linings.
On the other hand, a makeover can be a more budget-friendly and less disruptive choice, especially if the wardrobe is still in good condition. Adding flat-pack inserts is an easy way to improve functionality, while updating the doors and hinges can modernise its appearance. If you choose to give it a makeover, consider whether you want the hinges to be a design feature or hidden for a sleek, modern look. Hidden hinges, like soft-close hinges, are ideal for a minimalist style, while exposed decorative hinges can suit vintage or rustic aesthetics. Your choice will depend on the overall style you want for the space.
If you are happy with the internal layout, a coat of paint would improve the look substantially. You could also make adjustments to better suit the available inserts.
For the door, rebating the hinges so they are hidden would work well. Also, adding some trim work around the perimeter of the doors would look great.
Re: Remove built in wardrobe or makeover?
Hope you found Mitch's reply helpful. Let me tag a few experienced renovators for their thoughts @EllieBee.
@Alyce_Pham@raniia@Nicolarose@prettyliving@Upcycler01 - what do you think?
