Options
Plaster over a mirrored wall
August 2019
Hi has anyone had success with plastering over a mirrored wall. If so can you please share the method. Cheers
Re: Plaster over a mirrored wall
August 2019
Hi Collene,
You could actually paint over it, if that would help? I’ve done this successfully with a glass sliding door.
Steps:
1. Clean very thoroughly - there’s a really good Taubmans product in the paint section of Bunnos - should be with the Taubmans tile paint stuff.
2. I’ve used White Knight Grip-Lock Primer. One good coat, and allow it to dry and cure properly - at least 24 hours. Then paint with normal wall paint.
Hope this helps, cheers
Steps:
August 2019
Thank you so much. Very helpful. Cheers
You might also like...
Subject | Author | Posted | |
July 2021 | |||
October 2021 | |||
Wednesday | |||
August | |||
December 2023 |
