Complete makeover of Living and Dining Room on a Limited budget. Turned a dark old dated unit into a light and bright space.
Dining Room Before makeover
Lounge Room before makeover
Lounge before Make over
Lounge Before Make Over
Dining / Lounge Before Makeover
Dining after Make Over
Lounge After Makeover
After Make over
After - White Washed Walls
After Makeover
Hybrid Flooring was layed with a light Natural Oak Look.
Painted walls - Dulux Interior Feather soft colour
https://www.bunnings.com.au/dulux-15l-vivid-white-low-sheen-wash-wear-interior-paint_p1370160
Door and Trim Skirting Paint - (Best Cover that I have used)
White Washed Exposed Brick to lighten Space
https://www.bunnings.com.au/ppg-paint-4l-white-flat-tradepro-interior-ceiling-4l_p0498666
Primed and Spray Painted our Aircon as it was Yellowing from age. It was working perfectly so no need to replace and safe us thousands.
https://www.bunnings.com.au/dulux-325g-duramax-plastic-primer-spray-paint_p1400720
https://www.bunnings.com.au/dulux-300g-white-duramax-appliance-spray-paint_p1400865
Curtain Track - BLACK (This is not the exact one as it appears the one I used has been discontinued) But this product could be used too.
Fence Brush for White Wash Walls - Used on Mortar Lines
https://www.bunnings.com.au/monarch-100mm-fence-brush_p1667948
Paint Roller used on Interior Walls
Roller Frame
https://www.bunnings.com.au/paint-partner-230mm-roller-frame_p0202230
Sugar soap to wash Walls and skirtings before painting
https://www.bunnings.com.au/selleys-1l-wall-surface-cleaner-super- concentrate-sugar-soap_p1230181
Always my go-to Sanding sponge
https://www.bunnings.com.au/rocket-sanding-sponge-kit-10-pack_p1661616
Step 1. Remove all old window coverings and rails
Step 2. Wash all walls and skirting Trim
Step 3. Vaccume exposed brick Wall
Step 4. Paint All Walls
Step 5. White Wash Brick Feature Wall
Step 6. Paint Skirtings
Step 7. Paint Front Door and Frame
Step 8. Spray paint Yellowing Aircon unit
Step 9. Lay Hybrid Flooring
Step 10. Install Curtain Tracks and Curtains
Step 11. Install Lounge Cabinet to reflect Lounge Space
Step 12. Style the Area
Hi @LilyHamptons,
Thank you for sharing your lounge and dining renovation.
What a massive change you've made to this space.
The bright white paint and new flooring have really brightened the area making it look much more modern and welcoming.
The styling looks fantastic and really puts the finishing touches on the space.
Congratulations on a fantastic project.
