I have retro lamps and need these 2 light globe fittings. Does Bunnings have such products or would you advise I go to a specialist lighting store?
and the light bulb fittings on these are not making contact with bulbs ( are loose) resulting in the flickering of light ( wobbling globe) So anyway I know I need 2 new lamp / bulb fittings and want to know if Bunnings have these type of old lamp fittings ( photos attached) or is it specialist lighting shop I need? Much appreciate your advice.
Hi @ElleH
We sure do have a range of them below are just a few but there are more styles than this right besides each other in the electrical isle. It will be the same isle as power points and light switches.
Hello @ElleH
It's great that you've received excellent advice from @CSParnell. Just to add to the suggestions made, please make sure to bring your old fittings and the new bulb you purchased for your lamp. I suggest placing the old fittings side by side with the new fittings to make sure that they are the same height and width. I also propose putting the bulb inside the new fitting to make sure everything fits correctly.
It sounds like an interesting project, any photos you can provide while re-assembling the lamp would be very much appreciated.
