As a beginner, how could I stain my stair treads? Cabot's stuff told me to use sandwich method. Put clear coat first, and stain it later.
"Being your first time, the sandwich method would be best for you to achieve an even and consistent finish."
And what are the pros & cons for sandwich method and normal way( stain & vanish direct on timber)?
Attached photo is half way to sand it to bare timber(treads & hand rails only), risers and newels will be painted to white.
Thanks a lot!
Updated photo: Treads edge vanish has been stripped.sand the treads edge
Welcome to the Bunnings Workshop community @Mysquare. We're pleased to have you join us.
The Cabots team know their stuff so I'm sure their recommendation is a great way to go. Unfortunately our resident Bunnings D.I.Y. experts are not on hand to confirm at the moment, so let me tag a few other experienced members to get their advice on how to proceed: @Nailbag, @Dave-1 and @JoeAzza.
Thanks for your patience in the meantime.
Hi @Mysquare
I would have to agree with @Jason that the Cabot's people would be the experts when it comes to their products. From personal experience, once a clear coating has been applied to raw timber, any stain thats applied afterwards isn't going to soak in. This gives a completely different finish to applying stain first, then a clear afterwards.
Nailbag.
Thanks for tagging other experts who might can help.
Thanks for your advice.
Would like to know what the difference with those two different method.
Also, Cons & Pros.
Maybe I can test them with two ways.
Hello @Mysquare
One of the drawbacks of directly applying the stain on your timber surface if not done properly will create varying degrees of dark and light finishes. You'll also see where the brush strokes end and where it begins. Some Cabot's products can be diluted to allow you to paint a light stain first and apply a second to keep a uniform finish.
Your idea of testing both methods is exactly what I was going to suggest. My best advice is to grab a large piece of timber off cut, sanding it down and testing both methods next to each other. This will give you an idea of what the finish will look like once it is applied. You can then ask the other members of your family household for a vote on which finish they prefer.
Afternoon @Mysquare
Sorry I missed the post. Tho my thinking follows along with "Cabbots team know their prodcut the best and follow the instructions to the letter" and test on an offcut to be confidant its what you want. Especiially after all that sanding! That is effort plus!
Just as a side note I like oiling the timber, I like the feel it gives the timber and look. To oil your steps tho all the old varnish/clear coat would have to be gone otherwise it would stand out easily.
Thanks, will do.
