How to seal rubberwood with so it does not yellow?
HandyBird
I have purchased a havea table top from Bunnings to use as a desk top and I would like to seal/protect it. I however, do not want to lacquer it and have it turn yellow over time. I like the idea that lacquer is hard wearing but not sure what type keeps the natural colour of the wood. I have a water based varnish but not sure if all water based varnishes have this quality. I have read that CAB acrylics are good but can’t find anything that says that that’s what it is??
Re: What can I seal rubberwood with so thatnit does not yellow
Welcome to the Bunnings Workshop community @HandyBird. It's wonderful to have you join us, and many thanks for your question about coating timber.
It was typically older oil-based polyurethanes that suffered from severe yellowing due to sun exposure and age. Modern oil-based versions aren’t as affected, but they can still give timber a honey-coloured hue. Water-based polyurethanes, on the other hand, are generally quite clear and resist yellowing over time, so they should meet your criteria.
I’d recommend using Cabot’s Cabothane water-based, as it provides a durable finish while keeping the natural look of the rubberwood. That said, the water-based varnish you already have will likely work as well. I suggest testing it on the underside of the panel first to see how it looks before committing to the whole surface.
Thanks Mitchell. This is the varnish I have. I will give it a try on the underside, although how long does it take to start yellowing? I presumed this was an aging and uv exposure problem.
Re: How to seal rubberwood with so it does not yellow?
Hi @HandyBird,
The product you have chosen is an interior water-based varnish, so it should not be used in applications where it is regularly exposed to UV. As it is a clear satin varnish, there will be very little if any yellowing from this product.
Does that include through a window? Or does the type of UV that the glass allows through not cause yellowing? Secondly does the Cabot’s Cabothane have the same problem. It will be used on a desk next to a large window
Hi @HandyBird,
Yes, UV rays will still come through a window.
The product you have chosen is a modern water-based varnish in the same way this Cabot's Cabothane Clear is. Modern water-based varnishes are not yellowing in the same way older oil-based varnishes are.
