How to seal leaking timber windows set within a timber frame?
David4321
Building a Reputation
 Heavy rain comes in the top of our timber windows.  Have tried numerous rubber sealants.  Any ideas or suggestions?
Many thanks Bunnings
Regards
David
David4321
Re: How to seal leaking timber windows set within a timber frame
Hi JacobZ and Bunnings Team
Good progress thanks to ideas.
1) We found one cause of the leaks was a leak in the aluminium window-wall seal. See photograph 1.  This was allowing rain to enter the window area rather than being channeled down the protective awning.
2) Each window was closed by the use of one 'stay' only.  These windows need to be closed tight/locked by the use of two stays each side. Refer photo showing the double stay setup. Open windows use one stay each side - closed windows tighten through the use of the second stay.
 3) Syneco 'Door & Window Weather Seal then used for additional protection around the frame.
Regards
David4321
Noyade
Glad it got sorted @David4321 👍
David4321
Thanks Noyade.  Appreciated your advice and comments.
David4321
David4321
Thanks to everyone who has passed on advice on how to waterproof Timber windows in a brick home.
No more leaks even with all the recent rain! (Quality advice naturally.)
Regards
David4321
That's sensational to hear @David4321.
Many thanks for the update.
