Hi all,
I am repairing the rotten section of a timber sliding door which faces on the inside.
Thus far I used multiple coats of Earl's Wood Hardener over several days including a medical syringe to pump the hardener in multiple places along the section I am repairing. The section now has a glazed look to is and it quite hard to the touch. I then plan to undercoat, then wanting to use a filler, sand this back, undercoat, and then paint.
I have not had good success with Turbo Builders Bog and I have found that for applications like this it will eventually crack. So I was hopping for a flexible filler to use that can cope with flex. Wondering if something like the Polyfilla 450g Exterior Timber Filler might be a better solution?
Many thanks!
John.
Hi @johnk,
Thank you for your question.
What you've done so far is brilliant and it sounds like it's done a great job of hardening up the rotten sections. I've been surprised in the past by just how effective the Earl's Wood Hardener is.
The Polyfilla Exterior Timber Filler is the perfect product for filling those small cracks as it is slightly flexible to account for the movement and impacts the door will experience.
As you've already said, the process would be to fill the hole, sand it back, undercoat and then paint. It is likely worth taping the glass with ScotchBlue 48mm x 55m Original Multi-Surface Painter’s Masking Tape to prevent any scratches or errant paint, but other than that, there's not much I can add as you are already on the right track.
