How to repair a sliding door?
vica
Having an Impact
Hi,Good morning! I still need help from you all. The slide door of my bedroom moves not smoothly even difficulty sometimes. I squirted many times WD-40 to its track which is inside its frame,but not work long lasting. The foot of door is also off-center a bit. May I do sth. to improve it?Thank you!
Re: how to repair a slide door
Hi @vica . Many thanks for your question, I'd be happy to assist.
It sounds like there is a track or runner issue and that the door is misaligned. I would advise you to remove the door from the track system and inspect both the top roller assembly and the bottom guide for damage. You can generally do this by opening the door fully, lifting it up and then pulling the whole door towards you. You might notice damage to the rollers or flat spots on them and the guide on the bottom might be misaligned. If there are any damaged parts you will need to replace them and if you take some pictures I can attempt to find the replacement part.
If there are no damaged parts, check to see if the bottom guide is aligned correctly and is screwed securely into the ground. If this guide twists, in operation, it might be binding up with the door stopping motion. If everything else seems fine, apply a small amount of Valvoline 500g Multi-Purpose Grease to the top track with your finger. Please wear gloves whilst doing so as the track might be sharp. Ensure the grease gets onto the top-side of the track where the rollers are hanging on and then you can also apply a small amount to the rollers themselves. You'll find the grease will last much longer than the WD40 does.
If you need further assistance or had questions, please let me know.
Hi,thank you very much,I will repair it as what you say.
