How to repair a hole in a door?
Gill110
Hey, This is the first time that i am facing this issue so i need full guidance how to fix it. Hole in the door as you can see in the picture what filler( which will match the door colour), sander and equipment required for this whole thing?
Thanks in advance.
Re: Door repair
Hello @Gill110
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about repairing your door.
The general steps are to remove all the debris in the hole, put supporting timber inside the hole and fill the spot with builder's bog. Sand the surface down then prime and paint the surface.
I suggest having a quick look at these discussions:
You'll find plenty of ideas on how to repair a hole in your door in the discussions mentioned. I also recommend looking at this guide - How to repair a hole in an internal door
Re: How to repair a hole in a door?
Hi @Gill110,
I trust Eric's advice was helpful.
Just wanted to add that replacing the door might be an affordable alternative. Bunnings has a door installation service you could also utilise.
Please let us know if you need suggestions for suitable replacements if you go down that route.
All the best,
