There's always one isn't there! That small thing that frustrates you!! I'm trying to remove a wardrobe facing board (a cover that was masking the top of the sliding doors. All four screws were seriously embedded and about an inch from the base of the hole. I've got 3 and just can't shift the last one. Is this a brute strength thing or is there another trick to keep the screwdriver blade in the slot as I push up? It doesn't matter if I disfigure the board. Any suggestions? Photos hard to get.
Where there's a will...got it! A bit of brute strength and lateral thinking. I was able to pull it out (rather than unscrew it) by leveraging with a chisel. Problem solvered!
Great you got the screws out top work for trying different approaches.
Re pulling it a claw hammer might have helped onto the screw head or a wrecking bar with similar claw and it could go behind the timber and leverage it firmly out.
Next time you have that situation you can grab the screw with the damaged with vise grips locked on very tight and simply unscrew it.
Some times cutting the screws off at the wall is easyest solution it comes down to what you need to do and what you need to protect and save.
But you passed this DIY test with flying colours
Hi @DIYHaveaCrack,
That's brilliant to hear you had some success.
It's a bit late now, but I've had some success by levering the timber while unscrewing the screw. This puts some outward pressure on the screw and in combination with the rotational force applied to the screw head, it can often move things around enough for the screw to rotate out
Also, there's the old trick of placing a rubber band over the head of the screwdriver. The rubber is malleable so it forms to the shape of the slot and can often help grip it better than without it.
Regardless, good work finding your own solution to the problem.
