Hello BW,
Can you please advice on painting the chip in architrave. ( paint in white )
MM
Hi @nagumuthu
If the damage is not so bad, you can do a little bit of sanding and cleaning before painting it. I suggest using British Paints 250ml White Sample Pot to cover the area. Please make sure that you get plain white and not a coloured or tinted white.
Thanks Eric. Can you please recommend for the brush.
Hi @nagumuthu,
If your plan is to just touch up the chip and not paint the entire architrave then I'd recommend a small craft brush. Alternatively, if you are painting the entire architrave then I'd go for a UNi-PRO 50mm You Can Do It Angled Sash Cutter Brush.
Hi @nagumuthu
My go-to is Selley's quick drying Spakfilla. It is a thick paste-like substance, so can be molded into shape. There is usually a applicator that comes with it. If not, just use an old knife or clean ice-cream stick.
When dry, it's easy to sand smooth if the finish is bumpy. Spakfilla dries white so there is often no need to paint it!
Good luck!
Thanks Tyro for the recommendation.
