How to mount indoor swing to concrete ceiling?
Fancypants
Hi community,
I'd like to install a ceiling-mounted sensory swing in my ground floor apartment. I'm fairly sure the ceiling is concrete (it's definitely not plaster or timber) so I'd like to know what's the best, most secure, can-hold-the-most-weight way to mount the swing please? Will likely be me and the kid in there at the same time occasionally (approx 140kg combined), got the strata permission sorted. Thanks for your advice!
Inspiration imageInspiration image
Living area and ceilingLiving area and ceiling
Re: Best way to mount indoor swing in concrete ceiling
Hi @Fancypants,
Given the weight capacity and the type of installation you're looking for, I strongly recommend professional installation for your ceiling-mounted swing. The load you'll be placing on the swing, particularly with both you and your child in it (around 140kg), requires precise installation to ensure it's securely fixed and safe to use.
Concrete ceilings are solid, but mounting heavy loads in them requires specialised anchors and fixings. In most cases, you’ll need to drill into the concrete and install a heavy-duty fixing system, which may involve using chemical adhesives or anchor bolts to ensure the fixings are firmly secured in place.
A professional will be able to assess the structure of the ceiling and provide a solution that not only supports the weight but ensures the swing remains safe to use over time.
That's great to know, thanks heaps!
