How to install insect screen on louvre windows?
Sunda
Building a Reputation
Hi
We have Louvre windows in our room, and I like to install insect screen for the Summer.
We currently closed our windows at night to minimise mosquito activity.
It is getting warm and unfortunately, we are unable to install air conditioner due to the lack of solid wall.
Would you be able to advise me on this?
Please find the pic of the window for your reference.
Re: How to install insect screen on louvre windows?
Hi @Sunda,
Could we also please trouble you for a photo of the outside of the window? Just want to see if there's enough clearance to add a flyscreen to the exterior side without impacting the louvres. It's certainly not uncommon to have flyscreens on louve windows - we do at home.
Thanks,
Re: Install insect screen on Louvre windows
Hello @Sunda
Thanks for sharing your question about installing an insect screen on your louvre windows. If you can access the outside frame of your window, I suggest adding an extra frame in front of it using 70 x 35mm Outdoor Framing H3 Treated Pine - 2.4m. The purpose of the frame is to provide a gap between the insect screen that I'm about to suggest and the windowpane of your louvre window. Once the frame has been secured to the front of your window, I suggest having a look at this guide - How to build a flyscreen frame.
Once you've built your flyscreen secure it to the new frame you've installed in front of your window. You should now be able to open your window in the evenings. I also suggest having a look at Dynabreeze 450mm Oscillating Floor Fan to cool off your evenings.
Sunda
Thank you Jason.
I have attached the external of the louvre window for your reference.
Hope that helps?
Hi @Sunda,
Given your louvres extend out that far, it sounds like @EricL's solution of extending the frame to accommodate them would be the best solution. It doesn't look like you'd need quite as thick a timber as 70 x 35mm and could likely get away with a thinner Tas Oak moulding.
Let us know if you have any questions on how to go about doing so.
Sunda
Thank you!
Sunda
Got it. Thank you
almo
Hi, I have a similar situation. Could I ask how you would attach the extra frame to the existing (timber) frame?
Hello @almo
A lot will depend on the existing frame that you currently have. If your window does not reach the edge of the window frame you could use a timber piece that is not as thick as 70x35. You also have the option of cutting a 90x45 in half lengthwise. When it is this thickness, you can literally drill straight through it with a timber screw. But if it has to be thicker timber, you'll need to screw it from the sides on an angle.
Would it be possible for you to post a photo of your window in its open position? We can then estimate and make a recommendation as to how much timber you'll need to use.
almo
Thanks for getting back to me Eric.
I've uploaded some pics. So with the louvres fully open I would need to come off the frame by at least 55mm and the part of the frame I'd need to attach to is only aboIMG_9415.jpgIMG_9420.jpgIMG_9421.jpgut 23mm wide.IMG_9416.jpg
