How to hang 15kg mirror on hard-plastered brick?
BrendanJB
Hi everyone. I've done a bunch of DIY and handywork around the house, but have never done any masonry drilling before, so feeling a little out of my element in regards to sizes/lengths of plugs, screws, and bits.
I want to hang a 15kg wall mirror in my living room, which according to the owner is brick covered in hard plaster. The mirror has 2 mounting brackets on the back, shown in the photos below.
From what I've read, it seems like I should be using a wall plug and drill bit of the same diameter, and a screw that has a smaller diameter but a longer length, so it sticks out when fully driven? So drill 40mm deep with a 6mm masonry bit, tap in a 6x40mm wall plug, and drive in a 5x45mm screw? Would those dimensions support the weight of a 15kg mirror in brick?
Would very much appreciate any info, help, or advice!
Thanks in advance.
Brendan
Re: Hanging 15kg mirror on hard-plastered brick
Hi @BrendanJB,
What you've described is spot on.
This STAHL Masonry Kit 7mm Drill With 50mm Green Wall Plugs includes everything you'll need besides the drill. Just drill the hole, tap the plug in and then drive the screw in leaving the head proud of the wall to hang the mirror from.
You might like to have a look at How to hang just about anything for some further guidance.
Let me know if you have any further questions or require further assistance. I'm happy to help if required.
