How to get rid of ants swarming an indoor power outlet?
diynoob7
Hi guys
Recently there has been ants swarming around a power outlet in my study.
Any tips on getting rid of them without damaging the carpet or the wall paint?
Thanks.
Re: How to get rid of ants swarming an indoor power outlet?
Hello @diynoob7
To get rid of ants in your power point safely, start by turning off the power at the circuit breaker to avoid any risk. If you see ants inside the outlet, try using a vacuum with a nozzle attachment to remove them. Avoid spraying liquids or insecticides directly into the power point, as this can be dangerous. Instead, use ant bait stations like Mortein or Raid ant baits from the store, placing them near the power point so the ants take the bait back to the nest.
To prevent them from returning, check for entry points around the outlet and seal any small gaps with Selleys No More Gaps or a similar caulking product. If the infestation is severe or persists, consider engaging the services of a pest control specialist to inspect for deeper issues, as ants can sometimes nest inside walls and electrical components.
