How to fix broken metal piece?
jyoraniga
Please suggest how to fix the broken mental piece
Noyade
Re: best glue or welding
Good morning! @jyoraniga 😁
For me - I would be going down the welding path. It looks like the upright unscrews to reveal that 'mobile' insert? Hard to tell with the blue-tack(?)
I do see spot welds in your photos, so it's doable. Do you or anyone you know weld?
My little inverter would be set at a low amperage (~70 amps) with a 2mm rod. Just enough for a small spot weld.
Tap any slag off and clean the weld with a wire brush.
And you would need to repaint the area with a similar gold colour.
Akanksha
Retired Team Member
Retired Team Member
Re: How to fix broken metal piece?
Hello @jyoraniga,
A warm welcome to the Bunnings Workshop community! We're delighted to have you join us. As you can probably tell, this is a friendly and helpful community where our members ask questions, share ideas and offer advice related to all things D.I.Y., including improving their home and garden.
Sorry to hear about your broken metal ornament. Great to see you've received advice from Noyade. Our resident D.I.Y. expert @EricL will also be happy to assist you when he's back online later today.
Welcome once again.
Akanksha
Hello @jyoraniga
It's great that you've received excellent advice from @Noyade. Just to add to the suggestions made, I recommend having a look at PC Products 57g PC Metal Epoxy Putty. Looking at the photo you posted it seems an attempt was made to repair it using a similar product. This product that I've suggested is specifically made to repair steel. Please note that it has a very short handling time, it's important that the parts are ready to be joined together as soon as you remove the putty from the container.
Noyade
Good morning @jyoraniga
How did you get on with this? Did you try the 'metal' glue that @EricL recommended?
It looks like a very interesting product.
I was gonna buy/try it on an oven wall mount where the manufacturer's spot weld failed - but I wasn't sure if it would withstand high oven temperatures?
In the end - arc welder, 60 amps and 2.5mm rod.
jyoraniga
please suggest for welder
Hello all
can some one suggest a welding place I can take my metal candle holder for fixing
Re: please suggest for welder
Hi @jyoraniga,
Given the Bunnings Workshop community is an Australia and New Zealand-wide forum, it would be difficult for our members to suggest a welding business in your location. You might like to look towards services like Hipages and Air-Tasker to locate someone in your area that could complete this work.
Morning @jyoraniga
I think you should try the metal glue @EricL mentioned. It's worth a go and inexpensive.
I for one would love to see if it works and your feedback would be greatly appreciated. 👍
