How to fix a small hole in the wall?
siya
Hi
while moving furniture, we hit the wall too hard and now there’s a hole in it
how do I fix it?
thank you
Re: Hole in wall- how do i fix it?
Hello @siya
Thanks for sharing your question about fixing the hole in your wall. I suggest using the Selleys Spakfilla Wall Repair Kit. This has everything you'll need to repair the hole in your wall. It has a wall patch, sanding block, spatula and filler all in one pack.
If your wall is plain white, I suggest going to the paint specialist at the store and requesting for a Dulux 250ml White Sample Pot - 250ml. I propose using a standard brush to paint the surface of the patch repair.
Here is a handy step-by-step guide: How To Fix a Hole in the Wall
