How to fix a noisy ceiling fan vibrating noise?
vng
How do I fix a noisy ceiling fan that's making a humming noise (Vibration noise) ?
For some reason, it only makes creates this loud humming sound when it's on the mid speed setting and goes away whenever I either turn up the speed to high or the speed to lowest which means that the mid setting is never usable.
Is there some part it needs tightening ?
Arlec ceiling fan with light and remote  - I have the smaller version with remote
Re: How to fix a noisy ceiling fan vibrating noise?
Hi @vng
Thanks for sharing your question about your noisy ceiling fan. A mechanical problem will often reveal itself in any of the three general speeds. But since it only shows itself on mid speed, I suspect that it could be due to an electrical issue. There could be a wiring issue inside the fan, or the motor could be going bad.
I suggest engaging the services of a registered electrician and have them diagnose it. They'll be able to tell if there is something is wrong with the switch, wiring or fan itself.
However, should you decide to replace the ceiling fan itself, please note that the store does offer a Ceiling Fan Installation Service. I suggest visiting your local store and having a look at the ceiling fans available.
vng
Hi Eric, is it an electrical fault ? As if I were to hold it up alittle whilst on that setting, the vibration stops.
Hi @vng
It is difficult to guess what the issue is at this point as the interior of the ceiling fan is sealed. Even if you were to discover the fault inside the fan such as a worn bearing or a loose motor mount there would be no spare parts for it. The only option will be to replace the ceiling fan. However, if it is an electrical problem, you'll still need a registered electrician to inspect the connections. It could be the fan switch that is causing the problem, there might be a problem with the wiring.
I understand that it is very tempting to try and fix it, but keep in mind that this is a high voltage appliance. In the interest of health and safety, it's best to let the professional trades have a look at it.
