How to fix a big crack on bedroom wood door?
hoahy005
Hi all, I would really appreciate any advice on fixing a crack in my bedroom door. It’s quite large, and I’d like to repair it in a way that makes it as unnoticeable as possible. I’m not sure which product would work best for this, so any recommendations would be greatly appreciated. I’m on a tight budget, so I would prefer a decent yet affordable product. Thank you so much in advance! 😊
Re: How to fix a big crack on bedroom wood door?
Hello @hoahy005
Welcome to the Bunnings Workshop community. Its sensational to have you join us, and thanks for sharing your question about your broken door.
I suggest putting some PVA wood glue on one side of the crack and using your thumb to push the sides back together. When the glue has cured Cover the broken line with some UNi-PRO 500g Multi Purpose Interior Filler - 500g. Sand the surface to a fine finish then prime and paint the surface.
Good Evening @hoahy005
I would also be following @EricL 's suggestions. I do have a question tho.
Is there any deformation on the reverse side of the door? Internal doors are hollow/hollow wafer type deal so its just a close look check to make sure it hasnt been deformed too far.
Hi Dave, there is no defomation on the other side. The only damage is extrusion in the picture.
Morning @hoahy005
Cheering! Then I would follow @EricL 's steps. They are the same I would be stepping through.
Note your door looks like its a gloss surface, so when you go to repaint the door (id suggest the whole door repaint, well one side) keep it in mind when choosing the paint type (oil based or water based paint as if you put water based over oil you can end it with bubbles)
