I’ve just pulled a cupboard out of this space. It’s double brick, wondering if I can fill these holes in myself, or do I need a professional? If it’s something I could do, what products would I use? I’m assuming something more substantial than the filler I currently use for little patch up jobs. I’m getting it ready for wallpapering.
many thanks!
Thanks all!
thanks again.
spoken to Bunnings and they can’t cut the yellow tongue board because of the tongue. I think I can buy the 18mm particle panel standard and it should work just as well?
I’ve check and it’s just concrete below so I’ll pick up some of the liquid nails as you suggested.
Again, thank you all!
Afternoon @Becshouse
I wonder if they would cut it almost through bar teh last 3cm and then you could use a handsaw to finish it? That way you can get it home?
Thanks Dave.
Is the yellow tongue board a different material to the standard 18mm particle board? As in, do I definitely need the yellow tongue board even though I won’t be using the tongue part?
I would think that the yellow tounge board is diifferent, its been made for flooring use. I wouldnt really go another path on the board, Maybe think of your overall materials list and borrow a trailer from Bunnings (They are free for a short period) or hire a ute (Im temted to do that on some Mebau 4m lengths I need as it will be cheaper then the $70 delivery fee.
@EricL or @MitchellMc might be able to give you a defenite about the yellowtounge compare dto normal particle board tho.
Hey thanks Dave.
I guess I’m wondering as well as I won’t be walking on it/ using it as a floor as such. It’s a base for a cupboard to be build on top - cupboard on the left, shelf on the right for a desk.
Always better to start with the right stuff, how many times have we had to "fix" something that someone else has done before we get to start on the actual project is my rule of thumb
Hi @Becshouse
In this case it's better to be safe by using the right material for your flooring. I understand that it is tempting to use another material, but the yellow tounge is specifically made for flooring and it will maintain its structural integrity for a long time.
