How to clean or update vents for air con?
Just bought house. Evaporative sir con vents look so old and dirty. Not sure how u get them off to clean or can you get more clean and modern vents
Re: how to clean or update vents for air con
Just new to this
Hello @hopelesscarol
Welcome to the Bunnings Workshop community. It's wonderful to have you join us, and thanks for sharing your question about your ceiling vents.
Quite often if you don't see any screws on the outside of the vent it's possible that it's fixed in place with steel spring clips. I suggest using a flat head screwdriver and inserting it between your ceiling and the edge of the vent. Slowly pulldown on the screwdriver to lift the corner of the vent out. Once you see the clip of the corner, you'll have a better idea of where the other clips are.
Once you have the vent off you can use ordinary hot water and detergent to wash the grease and dirt buildup on the vent. If you are thinking of replacing it, just make sure to bring your old vent with you to make sure that new vent is the same size, and the new clips are located relatively in the same spot.
If you decide just to wash it, it's important that it's totally dry before you re-install it.
Since you'll be using a ladder, I suggest having a quick look at this guide - How to use a ladder safely by @Adam_W.
Re: How to clean or update vents for air con?
Do not lever edge of plastic vent!!! Push each louvre section upwards and rotate until they can be angled to remove from frame. Now carefully lever the metal (or plastic) springs so the housing can separated from the ceiling. Place all parts in dishwasher then reinsert parts in to ceiling when dry!
Hello @BigBad
Thank you for sharing your knowledge and experience regarding the ceiling vents. It sounds like you've done this quite a few times and have discovered the technique of ceiling vent removal. We're keen to hear more about all your projects and plans around the house and garden. Please feel free to reach out whenever you need assistance or would like to share a project with the community.
