How to add a marble-look wall panel behind TV?
Samara1
Having an Impact
Anyone did like this marble looking wall panel behind tv.
Looking for marble looking sheet or wall panel and which product is good to go and where to get it in Sydney.
Re: How to add a marble-look wall panel behind TV?
Hello @Samara1
There are two panels that are very close looking to what you are after and that is the Wall Art 2400 x 1200 x 3mm White Marble Wet Area Wall / Shower Panel and the Wall Art 2400 x 1200 x 3mm Carrara Ice Wet Area Wall / Shower Panel. These panels are at their biggest and are often used for shower applications so it can be used for decorative purposes. Although there are other marble patterns in the bench top range they are not as big as the two panels I've just mentioned.
Should you happen to pass by one of the stores, I strongly recommend checking these panels out and see if they will work for your TV wall panel project.
