How to add a closet wall wire shelf?
vng
Need some advice on whether this will fit this tiny closet space
Flexi storage - Home Solutions double slot system
Flexi Storage Home Solutions 2400mm White Double Slot Wardrobe Starter Kit
73cm wide (left to right) & 40cm Depth (deep)
Re: Closet wall wire shelf
Hi @vng,
Thank you for your question.
Unfortunately, the Flexi Storage Home Solutions 1800mm White Double Slot Wardrobe Starter Kit would not work as it is much too wide for your space.
Luckily, the Flexi Storage Home Solutions range is very customisable, and the handy Flexi Home Solutions Planner can be used to design something that will work for your space.
Have a play around with the planner and see what you think.
