DIY window nook
lifestylebymari
Making a Splash
DIY window nook
Turning a dead space into something beautiful and useful
My favourite things to do in a house is creating not only beautiful spaces but also spaces that can be useful and have a purpose. This little nook was the perfect opportunity to turn something that was wasted and unpractical into more storage as well has a spot to enjoy the sun.
Below are the materials I used to create this space:
- 9mm MDF Panel Standard 900 x 600mm (I/N: 0590030) x4
-12mm MDF Panel Standard 900 x 600mm (I/N: 0590036) x1
- Pinnacle 100mm Single Fixed Pin Butt Hinge (I/N: 0074252) x2
- Dulux paint I used casper white
- Foam and fabric
- Screws
- Brilliant Antique Brass Metta Interior Wall Light (I/N: 0014351)
I started by connecting the 4 base mfd panel of 9 mm with screws, followed by applying the hinged to the back panel and then applied the top panel. Painted every visible spot with 2 coats. And finish with creating the seat with foam and the fabric, I bought this one for this project but I would also recommend using any old or unused fabric you might have at home. I finish the project by also adding a wall light to create a more intimate and cosy vibe (this step I did get help from a family member who is an electrician)
I love how this DIY turned out and how I also created space to put all my cushions.
Hope you also enjoy it :smile:
9CBEEBE5-06BF-4006-8D26-47605DF6DE2E.jpeg59AD835D-3743-448F-BE25-34A87D5B1CCB.jpegCBAAB481-842D-4BF1-9E5D-7169D130A192.jpegDE05EF71-1553-4794-A9E6-EADD09545E6B.jpeg
Re: DIY window nook
Yay thank you so much
