In this DIY I have created a table that takes me to Europe. I was inspired by Portugal and Spain architect walls, the mosaic, and the different patterns that you would find in the walls. They were so beautiful and bring so much beauty to any space.
So once I have seen the Modello Wall Tiles at Bunnings I knew I had to create something with it. Found the table that was going to the bin and was so happy since it was a perfect size for the project.
Products I used:
- 1 box of 28 tile 20 cm x 20 cm
- Dunlop adhesive for timber and white grout
See the before and after below:
Another absolutely beautiful project @lifestylebymari.
Do you happen to have any photos taken while you were working on this project, or could you explain the process of tiling this table? Did you first sand it? I'm inspired by this project and would love to try it myself so I'm sure others in the community would also love to learn more about how they can give this a go.
Thanks for sharing.
Stevie
Of course, @StevieB , was such a fun project to complete. The following are the different steps that took me to complete the tile table:
Step 1: Clean the table really well with any cleaning tool
Step 2: Spray painted the legs with Dulux Metalshield Epoxy Enamel Spray Paint Flat Black
Step 3: Sanding the table with a 120 grid
Step 4: Place tile in the position I would like since they have a pattern
Step 5: Apply the Dunlop Wall and Floor tile Adhesive specific to apply directly on timber
Step 6: Apply tiles, let them dry for 24 hours
Step 7: Apply any white grout, I used Dunlop Ready to Go Colour
Step 8: SmoothTable after using the angle grinder the edges with an angle grinder
Step 9: Finish around the tile with outdoor black paint
Try it out and tag me so I can see your projects
What a beautiful mosaic table. It just gives that table a new look and feel. Thank you for sharing the photos and materials for your project. Will you be putting this table inside or outside your house? If you are planning to put this outside I suggest sealing the grout with Betta TileCare 300g Aerosol Tile And Grout Sealer to preserve your work and make it last a long time.
Again, thank you for sharing your amazing project.
Thank you, currently is under a pergola.
Thank you so much for the advice, definitely will look into it.
