DIY chalkboard wardrobe door using Dulux Chalboard Paint
Dulux Chalkboard Paint
Taubmans Advanced Adhesion and Mould Blocker Prep Coat
Nap Roller
Painters Tape
Chalk
Sugar Soap
Clean area thoroughly with sugar soap
Tape in preparation for painting and begin Primer if needed depending on your surface you may not need this specific primer. Refer to Paint instructions to see what is suitable for your surface ☺️
Apply two coats of Dulux Chalkboard Paint. Follow Dulux instructions for curing, I found you may need to wait a touch longer than what is recommended to make sure it’s fully cured and won’t scratch with the chalk. ☺️
Hi @monochromehaus,
Thank you for sharing this your chalkboard project.
Dulux Design Black Chalkboard Paint is a brilliant way to turn an otherwise unusable space into an area that will promote creativity and keep the kids from drawing on the other walls.
I'm sure Alexander will get a great deal of use from this wonderful project, and it will help his creativity flourish.
Congratulations on wonderful project.
