cindyh68
Cultivating a Following
Bookcase makeover from kerbside find
Kerbside Find: Before & After Kerbside Find: Before & AfterAfter initial clean the sanding process began After initial clean the sanding process beganVacuumed the dust & then cleaned with damp cloth Vacuumed the dust & then cleaned with damp clothTwo coats of undercoat all surfaces Two coats of undercoat all surfacesTwo coats top coat all surfaces Two coats top coat all surfacesFrom this.....to that From this.....to that
Re: Bookcase Makeover : Kerbside Find
Hello @cindyh68
Thank you very much for sharing your bookcase makeover project. Sometimes you have to use your imagination to see past the furniture's current condition. That black and white paint you've applied really makes the bookcase stand out. It looks so much better and it's fantastic that you've given this piece of furniture a second life.
Again, thank you for sharing such a wonderful project.
Re: Bookcase makeover from kerbside find
Well done @cindyh68 and many thanks for sharing.
Could you also share some tips for members who might like to upcycle their own piece of furniture? What are some of the things you learned or found most challenging during this project?
Thanks again,
