Can I use a 2400 x 900 x 33mm "SpecRite" Acacia panel as a barn door ?
Hi @XMech,
It is not the standard use for the 2400 x 900 x 33mm Specrite panels, but I can't see any reason you couldn't use it as a barn door.
The only issue I can foresee, is that barn door roller kits are usually designed for doors that are between 35-45mm thick, but this just means you may need to shorten a couple of bolts. This is relatively easy to do with a hacksaw if needs be.
You might like to check out these Barn door ideas for your home for some examples of similar projects.
