How to fix a burn mark on a kitchen benchtop?
JamieK
Hi there,
I was wanting to know best method to fix / paint a burn mark on a laminate ledge / shelf without replacing the whole sheet.
All advice is appreciated greatly
Thank you
JamieK
Re: How to fix a burn mark on benchtop laminate?
Welcome to the Bunnings Workshop community @jojo3831. It's wonderful to have you join us, and many thanks for your question about repairing a benchtop.
It appears you've done a great job at diminishing the appearance of the burn mark. It looks like the mark penetrated quite deeply into the benchtop surface. You've removed the top layer of the benchtop through sanding, which has taken out the majority of the mark, but it continues deeper into the surface. Removing the rest of the mark might not be possible due to the depth. You could look at polishing the surface, which would hopefully remove the scratch marks from the sanding. Also, if you've used, say, 600-grit, you can continue up the grits to 1200 or more to remove scratches from the more coarse grits.
Be advised that if this is a manufactured stone benchtop, you should not be sanding it as it contains silica, which can lead to serious health issues such as silicosis. If it is a manufactured stone benchtop or laminate, I recommend you enlist a professional to see if any further steps could be taken to remove the rest of the mark.
sanam8773
How to fix burned benchtop?
Hello , just need to idea to remove the burn stain from the benchtop
Re: burned benchtop
Welcome to the Bunnings Workshop community @sanam8773. It's sensational to have you join us, and many thanks for your question about a damage benchtop.
Could you please let me know if your benchtop is laminate or manufactured stone? Unfortunately, it’s unlikely that you can remove the burn marks, as they are typically not just stains but actual damage to the surface of the benchtop. In this case, you might want to consider reaching out to a professional who specialises in benchtop restoration and burn damage. They should be able to assess the damage and provide options for repair.
Hi Mitchell,
Thank you for your reply , any polishing product you recommend for this?
Hi @jojo3831,
There's not really a specific product for benchtops like yours, but you could try using this Glitz Beeswax Polish.
Use a microfibre cloth and work it in a circular motion to give the area a bit more shine.
Let me know what you think.
