Please advise if I can put something onto it to cover the existing kickboard? or should I remove and install a new kickboard? Thanks so much.
I plan to repaint mine.
Hi @clauzz,
If you were looking to replace it we have a great range of easy to install kickboards which will certainly fix the situation. Alternatively, you might like to consider painting it, by using a primer and then painting with a water-based enamel.
I painted the kickboard in our house several years ago with black water-based enamel and it has been a great solution.
If you need further advice on installing a kickboard or had questions, please let me know.
Thanks so much Mitchell.
Can you please recommend which primer and which water-based enamel I should try?
There are many products on the link that you provided.
Appreciate your assistance on this.
Hi @clauzz,
My preference would be Dulux Aquanamel as it is a premium hard wearing and chip resistant paint and British Paints Prep 4in1 for the primer.
Thank you!
