I purchased the Pope Indoor Tap Adaptor (https://www.bunnings.com.au/pope-indoor-tap-adaptor_p3111029?store=7132) to connect to a garden hose so I can water the plants on my balcony, but it doesn't fit my kitchen tap.
It looks like my tap is a 15mm connection. Is there a similar product that will fit?
Hi @gthom,
Thank you for your question and welcome to the Bunnings Workshop community, it is wonderful to have you join us.
I'd suggest returning the Pope adaptor and swapping it with a Kinetic Adaptor Aerator Kit.
This kit is designed for 15mm aerator connections and should be perfect for your application.
Thanks I will grab that one. I've already opened the Pope so can't return it.
Hi again Jacob,
so I got the adaptor you recommended and it still doesn't fit.
My tap seems to have a very short connection point. Here are some photos. If you have any other ideas that would be helpful.
Hello @gthom
Thank you for sharing those photos of your kitchen tap. Jacob's recommendation regarding the adaptor was actually correct. However, your tap is non-standard and will not work with the recommended Kinetic adapter. I suggest re-installing the aerator back on and using the Holman 12mm Plain Tap Adaptor With Clamp instead. This adapter works without a threaded end. Please note that it's best to keep the tap at low pressure to avoid blowing the adapter off.
Your other choice is to change your tap into something with a standard sized aerator or install a bypass tap under your sink connected to the cold outlet.
