Timber benchtop help
Hi everyone,
We sealed our timber benchtop on the weekend with a Cabot's clear flooring polyurethane (was told that this was perfect for benchtops) and it has not turned out how we expected...
We sanded the timber smooth using a belt sander/by hand until it was perfectly smooth.
We then applied x 2 coats of the polyurethane in a matt finish and it has dried with a rough 'raw timber' feel to it! We applied it with a gloss roller brush and brush (as per instructions).
It looks perfect - no streaks or imperfections. It is also water resistant.
I'm wondering if it is because we used a matt finish vs a gloss? Any suggestions?
Re: Timber benchtop help
Hey @KingStreetReno - the matte finish shouldn't have a 'raw timber' feel but it obviously won't feel as smooth as a gloss finish. I'd suggest going over the matte coat with a gloss coat if you'd prefer that smooth finish. You may have to sand the matte finish back before applying a gloss coat but I'm not 100% sure, hopefully someone on workshop has had some experience with it. The alternative is to call the manufacturer.
Hey @KingStreetReno
I would try lightly sanding the polyurethane that is on the benchtop currently, and apply a final coat with a brush, rather than the roller.
In my experience, I've found that flooring polyurethanes can bubble with a roller (and in your case with a matte finish, feel rough to touch.)
You could also try a flat head applicator, made from a sheepwool material.
I remember from this discussion about timber benchtops that some people were concerned about durability and ongoing maintenance. I will be interested to hear how you go with yours @KingStreetReno. Could you share a photo of how it has come up so far?
I am worried that you used a belt sander instead of an orbital sander to get your final pre coat finish. I don't believe that belt sanders are made for that.
As for your finish, matt/gloss, if you don't want that high gloss finish (that shows every imperfection) or a dull matt finish, try a Satin. Best of both worlds.
I also would recommend several coats with light hand sanding between each to obtain that showroom look.
Good luck.
