Removing stains from Caesarstone
snichols
Building a Reputation
Hi all,
Just wondering if anyone has any tips for removing stains from a Caesarstone benchtop? I've got a couple of very light rings on the benchtop - I think they are from putting pots on the bench. Usually the stone is very easy to clean - just needs a wipe, and occasionally some white cream cleaner but I can't seem to remove these marks.
Thanks,
Sarah
Kellie
Making a Splash
Re: Removing stains from Caesarstone
Be careful with heat. The stone will tolerate moderately hot pans etc for a brief period, but prolonged direct contact or radiated heat from very hot pots can cause discolouration and/or damage. You might need to contact Caesarstone if their cream cleaner hasn't worked.
CathD
Making a Splash
Good luck Sarah, I hope you remove the stains.
Stone_Guru
You have physically damaged to stone benchtop
Nothing off the shelf will fix this issue, it will have to be professionally repaired
Might be worth reading page 5 of this Care & Cleaning Essentials for Stone
https://stonebenchtopcleaner.com.au/sds/Quartz_Care&Maintanence_Essentials_(2018web)DSA_Rev4.pdf
Hi @Stone_Guru,
Thanks for joining in the discussion and sharing some advice. Let me extend a very warm welcome to the Workshop community.
