Hello,
Recently my hubby spilt some cooking oil which fell onto the kitchen drawers (photos attached).
We are currently renting and have tried to clean the stain with warm water and dish liquid, covering the stain/s in cornstarch and even rubbed a small amount of turpentine in a small area but haven't persisted with it. However, the stain/s is still there. Any further cleaning ideas?
Is it possible to varnish or oil it so that the stain looks uniform? Can you please advise what we can do or use so that it looks the same? We obviously don't want to spend a lot because we are renting but at least so that the stain is not that obvious. To me it looks like MDF. (There is a small amount of white laminate near one of the knobs it was covered in that has been cut out previously but not by us).
TIA,
Teresa
Good Morning @gardenia8888
Welcome to the Bunnings Community pages A good place for this type of question!
It does look like MDF dosnt it. And dosnt seem to have been sealed.
Two things come to mind,
- Paint it. There are paints that can be used for kitchen ceilings manufactured to cover an oily styled surface, Id warm wipe the excess if any is left and then remove the knobs and paint. Maybe something like this Dulux White Ceiling +PLUS Kitchen And Bathroom Paint - 1L
- If you can find a draw front that matches the design from second hand store or side of the road. Im sure ive seen similar designs around. I would replace it then. Its not supper urgent unless you are moving out So you could take your time and keep the paint solition as a back up?
Thank you, Dave, for your suggestions. Will keep them in mind. Only thing about the paintwork is that it would be more obvious that I painted it and am not sure if they would want it painted, but then again it might look better than what it is.
Hello Dave,
Since you suggested the painting and that it isn't sealed. Does it have to be sealed before painting? Thanks.
Hello @gardenia8888
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your kitchen drawers.
In order to paint the drawer fronts the surface must be sanded down to allow the paint to penetrate the surface. If it is MDF, I suggest sanding lightly so as not to damage or reduce the cut-out features of the drawer front. A little bit of effort can be applied to the oil-stained section of the drawer front. Another option is to try beeswax on the door to give it a uniform look. It will need to be repeated every now and then as the beeswax fades away.
It's best to document your plans and suggestions by email to your landlord so that there will be a record of the upgrades you are making to the property.
Hi Eric,
Thanks for your reply and suggestions, which is very helpful.
Like the idea of trying beeswax too, as it might be easier before trying to paint the drawers.
Let's see how it goes. Thanks.
Hello,
Can someone please advise what grit sandpaper would be advisable to use on these MDF kitchen drawers and any other paint you can recommend apart from the Dulux white ceiling kitchen and bathroom paint mentioned above, just so that I have more options?
TIA,
Teresa
Hi Teresa (@gardenia8888),
120-grit sandpaper is a good medium grit sandpaper for this kind of work. If you wanted to go a bit further after the initial sand with 120-grit, this 240 Grit Sandpaper will help you get a very nice surface before painting. It will also be handy for a light sand between coats of paint.
A water-based enamel paint, such as Dulux Aquanamel is a great option for this project. It can be tinted to a wide variety of colours and comes in a variety of finishes, with semi-gloss being a great option for kitchen cabinets.
You'll need to use a water-based primer such as this Dulux 1Step Prep Primer, Sealer & Undercoat before applying your enamel topcoat to ensure you achieve the best results.
Let me know what you think.
Thanks, Jacob, for all your suggestions. Now I have some ideas along with the others who have answered what to do moving forward.
Will let you know how I go when I go ahead with the job.
Hi @gardenia8888,
You might be already aware, but these drawer fronts are extremely degraded, so much so that the MDF is disintegrating and falling off. They once would have been white laminate, and that's been peeled off, revealing the MDF underneath. Exposed MDF is not a suitable material for use in kitchens, hence why the oil has stained it. What I'm getting at is that these drawer fronts should have been replaced or suitably sealed years ago.
Personally, I'd apply oil to the rest of them to create a uniform appearance. Spraying some Mr Sheen over the whole lot would likely work. Alternatively, approach your property manager and let them know that the drawer fronts are disintegrating. Ask them if the owner would be happy for you to paint them to improve their appearance and prevent further degradation.
