How to prepare Specrite Acacia Brown panel for use as a kitchen bench?
AuntieMaz
Hi ... what wax or oil would be most appropriate for preparing a Specrite panel for use as a kitchen bench?  My preference is for a matt natural look, but to be honest I'd MOST like the easiest, least time consuming option.
Re: Preparing Specrite Acacia Brown panel for use as a kitchen bench
Hello @AuntieMaz
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your Specrite panel.
I suggest using either Feast Watson 250ml Kitchen Timber Oil or Kaboodle 750ml Clear Hardwax Oil. Both coatings are oil based and can be applied with a brush. My best advice is to sand the surface of your Specrite panel as smooth as possible in order to get a superior finish. I also recommend testing a small section of your bench so that you can see what the finish will look like. If you are satisfied with the finish, then you can commit the whole panel.
