Im looking for a cheap solution to get this kitchen up to real estate open house condition. The cabinets aren't standard size and the replacement lead time is well into the middle of the year which is too late so I need to repair the cabinet front which is MDF and the cabinet doors which are chipboard. Already have the paint. What is the list of materials I need to do this.
Hello @threemonkeys
I suggest having a look at these three possible methods to fix your water damaged doors.
Any other laminate parts that are lifting up can be glued down using Parfix 500ml Fast Grip Adhesive.
Morning @threemonkeys
I would suggest to make some copys of the doors and replace the mdf as the easiest option. I dont think it will be easy to get the existing mdf doors back to a nice smooth surface. You could try sanding them but once mdf has expanded then you are really sanding a softer surface.
Once you have replaced the expanded material, then pain and seal. As they are mdf I would suggest a paint for a wetter area.
