How to ensure counter top finish with Dulux renovation range
Lorraine1
I've painted my counter tops 2 coats of Dulux Renovations Range -Domino.  Im about the go to the Dulux Satin Top Coat varnish for renovation range however im seeing some bad reviews for this product stating that it wastes job and leaves streaks / marks.  Has anyone used the clear top coat how long should I leave countertop to cure before applying top coat varnish or are there better spray products to use that won’t leave roller marks
Re: counter top \ Dulux renovation range
Hi @Kmegan80,
I've reached out to the Dulux technical team again and they'd like you to contact them directly if that's at all possible so they can open a ticket for you and get this issue resolved. If you could please go ahead and either call, start a live chat or use their enquiry form I trust they'll be of great assistance.
I do apologise for this inconvenience.
Thank you. Will do.
I have done several showers ok but had very similar streaky results on benchtop.
Read all the instructions, tried many times using different techniques, always streaky.
Very unhappy with this product on benchtops, waste of money and time
Welcome to the Bunnings Workshop community @alanericbarker.
Thank you for reaching out. I'm sorry to hear about the frustrating experience you've had. I understand how disappointing it can be when you’ve put in the effort and aren't getting the desired results.
Streakiness is most often caused by reworking areas that have already started curing, sometimes in less than five minutes, which interrupts the self-levelling process. However, I’d be more than happy to assist you further in troubleshooting or, if you prefer, I can help connect you with the Dulux technical team for more detailed support.
If you could kindly provide photos of the benchtop and a bit more information about the techniques you’ve used, I’d be glad to assist in working through this issue. We're here to help.
Let me know if you need a hand uploading images.
