I have an old Parker dining table set, great bones but the chairs are covered in ugly yellow vinyl. Apart from trying to recover in fabric, is it possible to actually paint vinyl successfully? The chairs won't be used daily as it is for a unit that I intend to rent out occasionally. Thanks in advance!
Welcome to the Bunnings Workshop community @linburnlane. It's fabulous to have you join us and many thanks for your question.
Yes, it is indeed possible to paint vinyl successfully. I'll need to check on Monday for you but we should be able to place a special order for Rust-Oleum's fabric and vinyl spray paint. Vinyl is plastic, so any spraypaint for plastics will stick to it. However, the Rust-Oleum product is flexible and specifically designed to withstand the movement associated with vinyl in particular.
I'll update you after the weekend on stock availability.
Hi @linburnlane,
I apologise for the delay in my reply. I've made contact with Rustoleum and they have advised that they have unfortunately discontinued their Rust-Oleum's fabric and vinyl spray paints.
Have you considered looking into vinyl stains as I believe that is another method of colouring vinyl?
Thanks for the reply. The delay was probably good because it made me look properly at the chairs and the seat was pretty easy to remove. And I covered it with a new fabric. Probably much easier than painting, in the long run. Haha!
