From attached photos, my lavenders kept spreading outwards. Planted in the corner of garden and property in corner of street. I made sure not over watering and not letting it too dry either. What should I do? Pull out and plant new ones? But new ones might be in same problem spreading outwards, so heavy going outwards that even breaking the roots ! It's Princess variety from Bunnings. See photos
Hello @MYC
Thanks for sharing your question about your lavenders. Your Princess Lavender is showing a common issue where the plants become woody and start spreading outwards, eventually breaking at the base. This happens when they put on a lot of soft new growth at the tips while the older, woody stems weaken and fail to support the weight. Since your plants are already breaking at the roots, it may be best to remove them and start fresh. However, to prevent the same problem with new ones, a few key steps will help keep them compact and healthy.
Regular pruning is essential to maintaining a neat shape. After each flowering, trim back about a third of the soft new growth, but avoid cutting into the old woody stems, as they rarely resprout. This encourages dense growth and prevents the plant from becoming too leggy.
When replanting, consider raising the soil slightly to improve drainage. Lavenders thrive in well-drained, sandy soil, so planting them on a small mound can help prevent root issues. Spacing is also important—if they are too crowded or pressed against a corner, they will naturally lean outward in search of space and light.
Avoid overfeeding with fertiliser or overly rich compost, as too much nutrition can cause rapid, weak growth. Lavender prefers lean, slightly dry soil with good air circulation around the roots.
If this variety continues to have issues, you might consider planting a sturdier type, such as a French lavender, which tends to hold its shape better over time. With the right care, your new plants should stay compact and thrive in your garden.
Hi Eric, thank you so much for your reply with helpful advice and suggestions. From the photos, if replace with French lavenders, should I put 2 or 1 lavenders? Currently that space have 2.
Also, please explain why not prune the old wood? With rises we remive dead dry branch, but not with Lavenders??
Thanks again
Miriam (myc)
Hello @MYC
I believe there is enough space for two plants. As I mentioned in my earlier reply, regular pruning is essential to maintaining a neat shape. After each flowering, trim back about a third of the soft new growth, but avoid cutting into the old woody stems, as they rarely resprout. The old woody stems do not generate new growth so there is no point in cutting them.
