we have cut off the plants with minimal damage and installed new fence in order to meet the new pool polity.
Can someone please advise the proper way to clear all the roots left?
also, what would be the best substitute to fill up the gaps with better landscaping result but don’t grow too much and quickly?
thanks
Hi @adamlin,
If the stumps aren't that large, you may be able to remove them yourself with the right tools and some effort. If they’re not too deeply rooted, you could try digging them out manually. Start by cutting off any remaining plant material at ground level and using a shovel or mattock to expose the roots. Once you’ve loosened the roots, you can try pulling them out with a pry bar or by using a saw to cut through any large roots. If the roots are still giving you trouble, you could also try using a stump grinder, which you can rent from Bunnings or hire from a professional service.
After removing the stumps, you’ll be left with the space to fill in. If you’re looking for plants that won’t grow too quickly or spread too much, consider low-growing, slow-spreading ground covers like native violets, creeping thyme, or dwarf mondo grass. These are all hardy and low-maintenance options that won’t take over the area. Alternatively, you could use decorative gravel or mulch to fill the gaps and create a tidy, low-maintenance garden bed.
